- 22 Mar 2009
- Cornwall
ok, so i had it running fine with ASRocks auto oc tool in the bios at 4.4GHz, but the vcore was 1.3-1.35v which was bumping up my temps. so i went into bios, turned off the auto oc and upped the multi to 44. great, vcore dropped to 1.2-1.27v under load and temps are about 3-5c lower, great........or so you would think. when running OCCT or prime, the multi when under load ranges from 38-44 it doesnt go to 44 and stop, it fluctuates.
if however i run windows scoring it runs at 4.4GHz all through the cpu/gfx/ram tests.
what am i doing wrong?
