- 22 Mar 2009
I do know blend test is far okay with bloomfield but get instability often on a sandybridge !
We still don't know what the max safe limit is. Many of us including myself are running at 1.4v
I'd say most will do that speed at 1.4v, i know of coupla really bad ones that needed like 1.39v for 4.5Ghz.
To be fair my foot, if you sell an overclocked product you don't 'guess' its stable you bloody well do it right or don't sell it. Guessing can lead to downtime and unneeded annoyance for the customer, and they bought the darn thing because likely they didn't want to be hassled or didn't know much about overclocking.
That isn't how a business works. It's far more time and cost effective to whack everything to a set voltage where 99.9% of products will be fine and sell them, then deal with the tiny quantity of returns. The alternative is to waste thousands of hours testing them all individually. If OcUK did that they would probably be out of business. No product range is 100% perfect as it's far too costly to achieve and brings no benefit at all the the business. Whatever the product, be it graphics cards, cars, or overclocks, you will have faulty units. Expecting otherwise is absurd.
If you sell something, then its in your interest to make sure your product works as advertised
You can't know if had an unstable machine if you haven't stress tested it for that long?![]()
done my last machine that way and it lasted 6 years stable, for me thats good enough lol.
mine just failed 59mins of prime. so i deffinatly wouldnt say 45mins to 1hour is enough.
i tend to go for 20 mins prime and then game away.
If it crashes in normal use then I up the voltage etc
Works for me!
Instability can cause chip degradation.
No it can't? It just means an unstable pc.
