That kit isn't free though![]()
Once more, said it somewhere else.
Kwik fit filled 1.6kg in my 330d, only needs 650g.
How did you find this out? Did you get a second opinion? I can't even begin to see how physically they could do that as the machine would have to fill it to an incredible pressure which I am loathe to believe itself would allow it to do.
Plus, I'm skeptical of anyone who signs up to a forum for their only posts to be about regassing their a/c ...
50 or 60 quid, just got to kwik fit, even they cant **** that up.
So if you overcharge the system what would the consequences be?
****ing hell...read the ****ing paper for 15 minutes![]()
But if ****ing recyles the gas. You're paying for some other ***** fridge gass![]()
They did my mates Audi S3. They did the aircon recharge just fine - shame they ripped off his front splitter reversing it out (manager of the place). It was actually one of the spanner monkeys that came over to tell him what had happened, the manager wasn't going to bother :|
Air con is one of the fastest ways to demist a screen as well so it can be used for a good chunk of the year.
What did they do then?
Also guys it's best to use your air con for like 20 mins a month at least to keep the system going I find.
Just got back from the local garage, as a result of Kwack-Fit telling me that they couldn't regass my AC because there was leak somewhere in it and it couldn't be filled up with any gas at all.
Local garage did the tests with some sort of dye and UV light, and regassed the whole system in less than 1 hour. Ice cold air con now. £10 cheaper than what Kwack-Fit would have charged as well. Unbelieveable.
I can't believe that it was possible that the the monkeys at Kwack-Fit could screw up something as simple as a re-gass.
