BFG 800W dead!
so i should go with this one then
Corsair Enthusiast Series TX 750W V2 High Performance '80 Plus Bronze
It's out of stock at OcUK and nearly £100.
I thought you were on a budget?
The TX 750W V2 gets decent reviews:
Corsair TX 750W V2 Review
Corsair Enthusiast Series TX750 V2 PSU Review
If you can afford £100 then it looks like a decent choice.
If you get one from elsewhere make sure it's a V2.
But if you're sticking to your budget the OCZ StealthXStream 2 700W will serve your needs.
The V2 doesn't really offer much over the older version, likely based on the slightly different base. Theres nothing wrong with the old V1 though.
If you shop around you can get it for £85 at which it is a bargain, but at £100 it isn't you can get better units for that.
From the reviews:
The TX750 V2 is another great power supply from Corsair which is a big improvement over the predecessor.
The Corsair TX750 V2 is a much needed fresh wind in the TX line's sails. After more than 3 years of sporting what is now an old design, the TX750W ship was moving across the water about as well as a dinghy in a whirlpool. Thankfully, the TX750 V2 does outperform the older TX750W in almost every way as it has a new mostly modern design, is well built and it is generally quiet.
Problem is they are just sweeping statements to prove that the V2 is necessary churned out either by Corsair or the reviewer without any hard data. If I had to put money on it I'd say the V2 is more about lowering per unit prices or moving to a new platform, or both. Sure it may offer slightly improved performance, but it won't be anything drastic going on the specs and 80 plus report.
Not saying there is anything wrong with the V2, just saying that the V1 might be old but it is a solid unit that out performs most everything at a similar price point.
I've no intention of getting into a big discussion about it but even if the V2 offers only "slightly improved performance" you might as well get one unless you can get the previous version a fair bit cheaper.
Yeah true, I just didn't see the point in quoting stuff that is clearly marketing drivel! ;) :D
The XFX Core Edition PRO850W looks good value and can be had for £70.79 on offer!
I am on a budget but when it comes to buying a psu its better to buy good than buy **** for the sake of a few quid right?
Correct, but there's nothing actually wrong with the OCZ PSU.
If spending a few quid more gives you peace of mind, and you can afford it, then go for a Corsair.
Just shop around for the best price on a V2.
Very true. Corsair are well known for their excellent reliablity and long warranties.
Indeed, make sure to shop around so you get the best deal.
As Surveyor mentions, there is nothing wrong with the OCZ, the cheaper price is more down to a shorter warranty than anything wrong with the unit itself. Personally I prefer to spend a bit extra to get longer warranty for peice of mind, which is why I buy EVGA for example, others prefer a dirt cheap price instead. There isn't a wrong way, just what ever suits you, your budget and you feel comfortable with! :)
