Keep in mind that the MSI Lightning is a long card and you'll need to make sure your case is compatible.
The 3GB Phantom is taking more than 2 slots.
3GB cards are designated for SLI under high resolution. A single GTX580 with 3GB vram is pointless in most cases.
Due to the nature that the 3GB cards are meant to setup SLI, I only recommend 3 versions of 3GB GTX580s:
a) MSI GTX580 Lightning Xtreme Edition
b) EVGA reference 3GB GTX580
c) Palit dual-slot 3GB GTX580
Do you think 1.5gb vram is enough for 3D gaming and a 27" 120hz monitor? like this one.
For upto 1080p 1.5GB is enough.
Hmz that looks bugged to me since at 3 times the resolution the same limitation at decent details did not work.
Only if reading and comprehension are advanced skills to you[H] Reviews are meaningless
If you need reviews to hold your hand and just point to the biggest number then sure, stick to the predictable canned benchmarks on other sites.Only if reading and comprehension are advanced skills to youIf you need reviews to hold your hand and just point to the biggest number then sure, stick to the predictable canned benchmarks on other sites.
[H] Reviews are meaningless imo due to their testing methods, even apples to apples aren't the most enlightening, the rest are easily skewed to show anything you want and very obviously selectively picked sometimes.
I take it you're not keen on the canned benchmarks either then? I like hardocp reviews precisely because they go outside of the norm, sometimes they frustrate because they don't test enough at mainstream res (Kyle is obviously obsessed with multi-screen gaming) and I wouldn't use the results exclusively to choose which graphics card to buy, but the tests aren't meaningless. They provide a useful alternative that can expose strengths and weaknesses not shown in other reviews, and if they cause controversy that should be a good thing as it prompts others to look more deeply at specific issues.
