Going to a sandybridge from a q6600 will gain you between 20 and 50 fps depending on game gpu and settings ect so what you really need to ask yourself is do i need the extra frame rate and is it woth the outlay to get it or can you get same or better with a gpu upgrade instead.
I upgraded from a q6800 @ 3.8 to a i7 930 @ 3.8 to a 2600k @ 4.8 and got gains with each upgrade.
Did i need the extra speed no but i upgraded just cos i could and i wanted to play with new tech.
Theres always something newer and faster coming just around the corner so it is tricky to decide when to upgrade so if moneys tight upgrade when your rig struggles with the games you want to play and a new sandy will give a good boost over a old q6600
http://www.anandtech.com/show/4083/...core-i7-2600k-i5-2500k-core-i3-2100-tested/20
Id think a q6600 @ 3.6 or so wouldnt bottleneck a 5850 at all and its only when you get into multi gpu would you see gains from the cpu.
i did the same thing ,but went from a q6600 and gtx260 ,to a gtx560ti,and the fps in games were the same,my q6600 was overclocked 3,4ghzWell, I just changed an 8800gtx for a 560ti OC on my Q6600 system and it has made very little difference to frame rates, so I think I can quite comfortably say that the CPU is bottlenecking it. I am getting approx 30 FPS avg in BFBC2, GTA4 still runs like a dog and is unplayable unless I turn the shadows off, and Just Cause 2 is around 30-40fps. This is at 1680x1050.
One thing I can do though is turn all the quality settings up to max on most games and the FPS hardly changes. Minimum frame rates seem better too.
Always thought there would be some kind of performance hit from the Q6600 and DDR2, but not that it would be this bad. I5 2500K here I come (when I can afford it)
I appreciate that my overclock is fairly small - I'd love to increase it, but my mobo is a total sod when overclocking quad core chips, even though the Q6600 should be fairly easy to do.
However, while a bit of a bigger overclock, and potentially having better ram might improve things slightly FPS-wise, it's not going to be nearly enough to remove the CPU bottleneck all together.
So...not really any difference then? Unless you play a game that utilises 4 cores which was very uncommon 3 years ago.feels like when i upgraded from core 2 duo to core 2 quad 3 years ago.
imho Q6600 is not brilliant for high res gaming anymore,mine was oc @ 3.6 & my games ran average at most but when compared to my i5 2500k i realized how ****e they ran on Q6600.
gaming with i5 2500k will leave a smile on your face.![]()
i have a q6600 at 3ghz and a 5870 - im telling you now bc2 runs flawlessly 60fps no stutter, max settings - so no idea why you are getting low fps.... voor could be right it might be dodgy ram???
