- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Strictly limited to 15 units of each, the Antec coolers are amazing in price! You snooze, you lose.
Antec Kuhler Shelf High Performance CPU Cooler (Socket LGA775/LGA1156/LGA1366/AM2/AM2+/AM3) @ £16.99 inc VAT
Defeat heat created by your processor and allow for improved operation with Antec's KÜHLER shelf. Designed for compatibility with leading desktop processor sockets, the KÜHLER shelf supports Intel® Core™ i7, Core™ i5 and AMD® Phenom™II, among others. This high-performance CPU cooler features a whisper-quiet 120mm PWM fan that blows downward, cooling both your CPU and chipset, and seven heat pipes for maximum heat transference. And, it's never been easier to mount your CPU cooler; Antec's KÜHLER shelf comes with an easy-installation kit with included mini-wrench for simple, fast and frustration-free set-up.
- CPU cooler for Intel® sockets LGA 1366, 1156, 775 and AMD® sockets AM2, AM2+, AM3
- 120mm PWM fan for whisper-quiet operation
- Seven heat pipes for optimal heat transference
- Rubber fan grommets reduce vibration
- Includes easy-installation kit
- Antec Quality 2-year parts and labor warranty
- Unit Dimension: 143 mm (H) x 120 mm (W) x 138 mm (D)
Only £16.99 inc VAT.
ORDER NOW
Antec Kuhler Box High Performance CPU Cooler (Socket LGA775/LGA1156/LGA1366/AM2/AM2+/AM3) @ £16.99 inc VAT
Defeat heat created by your processor and allow for improved operation with Antec's KÜHLER box. Designed for compatibility with leading desktop processor sockets, the KÜHLER box supports Intel® Core™ i7, Core™ i5 and AMD® Phenom™ II, among others. This high-performance CPU cooler features a whisper-quiet 120 mm PWM fan positioned between two massive heatsinks with eight embedded heat pipes, achieving maximum heat transference. And, it's never been easier to mount your CPU cooler; Antec's KÜHLER box comes with an easy-installation kit with included mini-wrench for simple, fast and frustration-free set-up.
- CPU cooler for Intel® sockets LGA 1366, 1156, 775 and AMD® sockets AM3, AM2+, AM2
- 120 mm PWM fan for whisper-quiet operation
- Two aluminum heatsinks for maximum heat conduction
- Eight heat pipes for optimal heat transference
- Unit Dimension: 148 mm (H) x 122 mm (W) x 120 mm (D)
ORDER NOW
Antec Kuhler Flow High Performance CPU Cooler (Socket LGA775/LGA1156/LGA1366/AM2/AM2+/AM3) @ £16.99 inc VAT
Defeat heat created by your processor and allow for improved operation with Antec's KÜHLER flow. Designed for compatibility with leading desktop processor sockets, the KÜHLER flow supports Intel® Core™ i7, Core™ i5 and AMD® Phenom™ II, among others. This high-performance CPU cooler features a whisper-quiet 120 mm PWM fan that works with your case's airflow to effectively force out heat created by your processor and rubber fan grommets to reduce vibration. Plus, it's never been easier to mount your CPU cooler; Antec's KÜHLER flow comes with an easy-installation kit with included mini-wrench for simple, fast and frustration-free set-up.
- Unit Dimension: 160 mm (H) x 122 mm (W) x 88 mm (D)
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
