Will this pump be able to pump CPU and GPU blocks?
4 Jun 2010
The pump is a "X2O 750 12V Pump/Reservoir" as i'm planning to buy the XSPC Rada RX360 kit and adding a GPU waterblock to the loop, somthing like a 5870 or a 6950. Also how shall i order it? I'm thinking GPU>>>CPU?
Thanks
Freddie :)
Yes, its a very good pump for a combo, l've used one, l went Rad > res-pump > CPU > GPU > back to Rad, but in the end the loop temp levels out.
Aye, it works for me! Check out the watercooling sticky if you need anymore advice. Either that or my build log, I used this pump in both those threads :)
Oh and as the cpu block is quite restrictive, it's probably best to order it this way. Pump>CPU>Rad>GPU>Res. It shouldn't really make much difference, but that is probably the neatest way of doing it. Again, check out the watercooling sticky :)
nice thanks guys! o and shayper i have already looked at your sticky and your build log! and i can also see that you are quite happy about your post being stickied :D
Thanks again :)
Thanks again :)
Well, it's a major achievement! Took about 3 hours all told to do that guide lol, 2 hours writing it on the iphone, and 1 hour reformatting it and adding links and pics :)
Enjoy your build, I wanna see some piccies :D
I will! might have to wait though :( build has been delayed until early august due to funds but I am getting everything ready in my head for when i click buy! I know how hard it can be typing paragraphs on iphones, well done though :) hopfully you wont be so hung over after the Birighton meet to look at pics :D
Aww that sucks! Hopefully nothing goes wrong with yours, I've just spent the best part of two days fixing my 580 -.-.
And yeah, I'm so happy I got my screen fixed, typing on it while cracked was horrible :(
Nice one :)
I would be happy to link it in to the watercooling sticky as an example if you do a good job ;)
1 more question if i may ;p
apart from apperance, is it worth forking out around £25 for compression fittings where i can just use barbs and clips? I doubt it would look that bad even with the barbs but just wondered if they are more safer etc...
Thanks
Hi, get Compression Fittings, the time you fork out for a barb and hose clip, l bought non-branded Compression Fittings made in Germany under £3 each, never had any trouble.
