Looking for a quiet case.
The 3 180mm fans have a low/high setting, by most accounts they are very quiet on 'low' and not a lot louder on 'high' - if they are not on the lower setting you could try that.
I thought the h50 was compatible? What problems are you having?
(Not that I own either a h50 or the FT-02 but I'm sure somebody knowledgable will come along with an answer!)
The heat sink is too big. I've tried all directions, flipping it ect and there is nothing I can remove to make it fit.
Errr H50 fits fine in my FT02, have you tried using push-pull fan config, drops the heatsink a little away from the top of the case and may give you some more room to play with. Thats how mine is and it fits no probs, also should improve your cooling a degree or two.
Hawker
yeh I have also had a H50 installed in my FT02, as hawker says make sure you attach the fan to the case, and then the rad to the fan, pull configuration should be just as good, add another fan pushing, for even better temps
On the subject of the FT02, I can't quite believe what I'm seeing in the MM - two red interior models! :eek: :eek:
Shame I don't go for large cases anymore.
