- 22 Mar 2009
- Cornwall
not really.
the guaranteed 4.8GHz CPU gives the end user piece of mind that it has hit those speeds before they buy. we do state the hardware that the overclock is achieved on for the customers own reference. if they choose to use different hardware then that's obviously their own decision.
the main thing is that 4.8GHz can be a difficult clock to achieve on low volts so it is a much better idea having an advantageous starting point. i.e. a cherry picked CPU.
i get that, but if the purchaser (like in the instance of the OP) doesnt know what settings you used, then its not really beneficial. and even if they purchased the exact same models as you, does that guarantee those products will perform exactly the same as they did in your workshop?
i dont know enough about OC'ing, so im not trying to say you are wrong, im merely asking.
