The only reason you will have needed to wait for the switchover if Freeview HD is already transmitting is if the the Mux the HD channels are on was low power and you couldn't get a signal and now they're transmitting at a higher power without analogue on the transmitter.
If you are on the Sudbury transmitter which I guess you are like me , the switchover is in 2 stages with the final analogue switch off on the 20th July , they then start HD on C47 , they aren't broadcasting it yet .
