I built my new system last week:
CPU: i7 2600K
RAM: Kingston HyperX Blu 1333mhz (16GB)
GPU: Gigabyte GTX 560 ti (SLI)
Mobo: Asrock z68 extreme 4
SSD: Crucial M4 128GB
OS: Windows 7 Ultimate x64
experiencing the following problem:
Computer restarts -> launches into startup repair -> startup repair fails -> cannot boot into operating system (stuck in an infinite startup repair loop)
Solution:
Enter command prompt in the recovery environment and use:
bootrec /fixmbr
= enables me to boot into my operating system again
My problem:
The "mbr" data is frequently becoming corrupt and stopping me from being able to boot into my OS until I rebuild it. In addition, all events that take place during the power cycle beforehand are lost next time I am able to boot into the OS. This means any programs installed/adjustments to firefox favourites or profile settings in applications are seemingly being reset to an older state.
Does this sound like an SSD issue? From extensive research I am yet to find any solid evidence on what can cause this problem. It has been suggested that the motherboard/RAM/PSU can also cause data corruption. I would like to narrow it down to either the motherboard or the SSD as I have already tested the RAM and PSU in a stable system. I can isolate between the SSD and mobo by installing Windows to another HDD and seeing if the problem still exists.
Sadly, I do not know how to replicate the problem. It has occured five times while I was not at the computer/computer was idle. This is frustrating because I have been using the computer for 90% of the time it has been on, but I am yet to actually see it restart-->go into startup repair. For this reason I am reluctant to test between the motherboard and SSD as it could take a long time to replicate the problem.
1) Do you think I have enough evidence to suggest the SSD is the culprit?
2) Has anyone else experienced similar issues before with regards to data loss/mbr corruption?
3) Anything else I should look into? Viruses/bad drivers/BIOS?
4) For reference, I have tried formatting/reinstalling windows to no avail and the disk I am using to install Windows 7 works fine on other machines
CPU: i7 2600K
Solution:
bootrec /fixmbr
My problem:
