Hi Everyone.
It's been quite awhile since I last built a PC and so much has changed. I'm looking to replace an athlon X2 6000 to play the latest and greatest on top res for at least a little while to come. I have spec'd up the machine below (Budget of no more than £1200 if I can help it) Was wondering if I have made any bad choices or whether there is anything I should add like water cooling or solid state disks etc...
If I have gone a little too far on some items or if I won't see benefit from them compared to an alternative please tell me
All input appreciated.
Coolermaster CM690-II Advanced Case - Black - £79.99
Intel Core I7 970 3.20GHz Hex Core Processor - £439.99
Asus Sabertooth Intel X58 Mainboard - £149.98
Corsair XMS3 6GB 1600MHz CAS9 Memory Kit - £52.79 (Might upgrade to 12GB 3 x 4GB)
OcUK GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card - £249.98 Seagate Barracuda 7200.12 1TB SATA 6Gb/s 32MB Cache - OEM (ST31000524AS) - £43.99
OcUK 22x DVD±RW SATA ReWriter (Black) - £16.99
Asus Xonar DG 5.1 PCI Sound Card with built in Headphone AMP - £20.99
Corsair TX 850W V2 Power Supply -£109.99
Current System
Asus M2N-SLI DELUXE (nVidia nForce 570SLI Chipset)
AMD Athlon 64 X2 6000+
4GB RAM DDR2 (2 x 2GB)
NVIDIA GeForce 9800 GT (Current Resolution - 1920x1080 @ 60Hz)
850W Antec PSU
Single 500GB SATA Hdd
Windows 7 (x64)
DVD/RW Drive
Onboard Sound
22" ViewSonic Monitor (VX2260WM)
Case - Thermaltake Mambo (Not a great choice at the time...)
Current System
850W Antec PSU
Windows 7 (x64)
DVD/RW Drive
Onboard Sound
