** THREE VERY SPECIAL NEW CARDS COMING TO OCUK! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Three new cards arriving next at OcUK which are rather special:-
Asus GeForce GTX 580 Matrix 1536MB GDDR5 PCI-Express Graphics Card @ £419.99 inc VAT
The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in.
In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers.
TweakIt provides users with flexible overclocking control even when running benchmark programs! The “+” and “-” button puts overvolting adjustments in the user´s fingertips, offering them performance optimization options during game play to gain the competitive edge.
ProbeIt takes the guesswork out of locating the graphics card´s measurement points, identifying them clearly in the form of 6 sets of detection points so you´ll know exactly where to get quick yet accurate readings using a multimeter.
Safe Mode button resets the graphics card back to default frequencies & BIOS. This is a very welcomed feature for hardware enthusiasts, think of it like the "Clear CMOS" on a motherboard.
Built with exclusive 19-phase Super Alloy Power technology, the MATRIX GTX 580 guarantees much greater overclocking headroom, with a 15% performance boost, 2.5 times longer lifespan and 35°C cooler operation than the reference card design.
Cooling is well taken care of by exclusive DirectCU II technology that puts copper heat pipes in direct contact with the GPU. The pipes efficiently transfer heat through two massive fans that deliver 600% more airflow than the reference design, resulting in a 20% lower operating temperatures.
A multicolored LED MATRIX indicator at the rear of the ROG MATRIX GTX 580 gives an instant and easy-to-understand visual display of the current GPU load.
Features:-
- Overclocking hardware tools, TweakIt and ProbeIt are directly embedded onto the graphics card firmware, while a Safe Mode button offers an easy reset option worry-free hardware overclocking.
- All new GPU Tweak provides professional graphics overclocking for PC enthusiasts
- 19-phase Super Alloy Power technology provides more headroom for overclocking with a 15% performance boost, reduced running temperatures and prolonged product lifespan
- Award-winning DirectCU II thermal technology with sound-dampened dual fans provides 600% greater airflow and 20% cooler performance than the reference design.
- Core Clock: 816MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1632MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters), 1x DisplayPort.
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
Only £419.99 inc VAT.
ORDER NOW
VTX3D ATI Radeon HD 6870 X2 Edition 2048MB GDDR5 PCI-Express Graphics Card @ £344.99 inc VAT
nonl2brWith more than twice the processing power of previous generation AMD discrete graphics cards, ATI Radeon HD 6800 Series graphics cards deliver a cinematic gaming experience and unprecedented performance.<br><br>
This special edition card from VTX3D combines the power of two 6870's and uses the bridge chip from a 6990 resulting in GTX 580 beating performance for a lower price. <br><br>
Features:-<br>
- PCI ExpressR 2.1 x16 bus interface <br>
- 2*256-bit GDDR5 memory interface <br>
- MicrosoftR DirectXR 11 support <br>
- Core Clock: 900MHz<br>
- Memory: 2048MB GDDR5<br>
- Memory Clock: 4200MHz (Effective)<br>
- Processing Cores: 2240<br>
- Bus Type: PCI-Express 2.1<br>
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort<br>
- HDCP Capable<br>
- DirectX 11 Support<br>
- OpenGL 3.2 Support<br>
- ATI CrossFire Ready<br>
- ATI Eyefinity Technology<br>
- ATI Avivo HD<br>
- ATI Stream Technology<br>
- ATI HD3D Technology<br>
- Warranty: 2 Years<br>
- Product Review: http://www.kitguru.net/components/graphic-cards/zardon/vtx3d-hd6870-x2-review/<br>
<br>
<CENTER><IMG SRC="http://www.kitguru.net/wp-content/uploads/2011/07/WORTH-BUYING3-300x300.png" width="150" height="150"/></CENTER>
Only £344.99 inc VAT.
ORDER NOW
HIS ATI Radeon HD 6950 IceQ X Turbo 2048MB GDDR5 PCI-Express Graphics Card @ £219.98 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Core Clock: 840MHz
- Memory Clock: 5120MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- Shader Model 5.0 Support
- ATI Avivo HD
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required (Power Adapters included in box for older PSU's)
- 450W minimum PSU recommended
- Warranty: 2 Years
Only £219.98 inc VAT.
ORDER NOW
bit late on the iceq? It has been on another website for a while now.
I want the 6870x2, it's a 580 beater :D
hmm that 6950 looks like the type of colour to really glow if you had some UV lighting in the case. :D On it's own though it looks like cheap plastic :(
Yeh it is a 580 beater and looks a nice card too, suppose for non crossfire boards its an option but CF6870 beats it hands down for value.:)
If only that 6870x2 was £40-50 cheaper...
For anyone with a Crossfire enabled board, two 6870s are a better and cheaper option.
Speaking of new cards, are we going to see the 6970 Lightning again? If not, that was a short run card!
the good thing about the 6870x2 though is that you can have 2 in quadfire :D
Yeah, I'd noticed that. I don't see how? Presumably the 68xx GPUs do actually allow for it, and no-one had made a card with both sets of fingers to prevent sales of 68xx cards impacting on the higher end cards, like the 5770 did on the 58xx.
