This Weekend Only, we have the perfect memory solution and housing for your new hardware. The Antec 1200 has powerful cooling and has a dominance appeal.
Antec 1200 Twelve Hundred Ultimate Gaming Case - Black @ £107.99 inc VAT
The Antec Twelve Hundred is the evolution of the best-selling Nine Hundred, expanding on its award-winning design with even more cooling, capacity, and convenience. The Twelve Hundred is incredibly robust, with 12 drive bays, 7 expansion slots, and space for even the largest graphics cards. To keep the most demanding systems nice and cool, the Twelve Hundred boasts an unprecedented cooling system, with a top mounted 200mm blue LED fan, two rear blue LED 120mm fans, and three front blue LED 120mm fans to cool the HDD cages. Factor in convenient features like front mounted USB, eSATA, and HD audio ports, and the Twelve Hundred obliterates the competition.
- 12 Drive Bays
- 7 expansion slots
- Advanced cooling system
- No power supply included
- Motherboard: Up to standard ATX
- Top mounted I/O ports for easy access
- Perforated front bezel for maximum air intake
- Washable air filters reduce dust build up in your system
- Convenient top accessory tray for a personal media player
Only £107.99 inc VAT.
ORDER NOW
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) @ £59.99 inc VAT
This 8GB twin kit memory solution has been designed specifically to support the Intel Core i5 and Core i7 dual channel memory DDR3 solutions. This solution runs at an incredibly fast 1600MHz at CAS latency of 9-9-9-24. So not only do you get to run your Intel Core i5 or Core i7 dual channel memory system at 1600MHz but with these tight Latency timings your system performance will rock..
- 8GB memory kit (2 x 4GB) for use with Dual Channel DDR3 Intel Core i5 and Core i7 processors
- 1600MHz
- Latency of 9-9-9-24 for maximum reliability and performance
- Intel XMP (Extreme Memory Profile) Support
- XMS Heat Spreader
- Limited Lifetime Warranty
- Sandybridge compatible
Only £59.99 inc VAT.
ORDER NOW
- 12 Drive Bays
- 7 expansion slots
ORDER NOW
- 1600MHz
- XMS Heat Spreader
ORDER NOW
