Really? I thought with the good reviews i read they would be pretty good at their intended purpose?
Can i ask you to expand on why they are 'complete crap'?
Due to the fact they rely on an electrical charge being passed through the body their results are massively affected by your hydration levels, to be honest they may be useful for tracking trends in your bf levels but dont expect the numbers they give you to be close to what you would get if you had a proper calliper test.
Thirded, and i have the ones you are about to buy.
They are really accurate with weight, and really helped with my weight loss, but the BF % have not been that accurate. A trainer i know had the hand held ones and they gave odd results too.
Weight accuracy - good. BF percentage readings from these scales haven't been as useful as i would have hoped.
Ok thanks guys, went and got it anyways.
I had a look at the calipers, but the reviews they were getting were even worse than the scales for dodgy readings.
I imagine that the nice feeling of seeing the figures going the right way would provide that little bit reward / incentive to keep on working hard! Similar to when you jump on the scales to see you have lost a good few pound but cant quite see it in the mirror.
Equally you could be holding a little water that isn't visible in the mirror, but you hop on the scales and you're 5lbs heavier.
PS suggesting scales and mirror would be the best bet.
I suggest you try measuring your bodyfat with the scales, then spend the next few hours drinking a fair bit of water, and measure again. Tell us what the difference is!
