LG W2363D 23 - good choice?
5 Jun 2005
Southampton
thinking of getting the LG W2363D 23, to replace my syncmaster 2032...
i need a new screen as gonna use the syncmaster on another build, will i notice much of an improvement on gaming? or shall i keep the samsung and just get a cheap screen for the 2nd rig?
if you use hdmi there is a mode called thru-mode which makes it have no input lag whatsoever :D I don't notice any lag personally and I use DVI-D
I was looking at the monitor to hook up to my xbox 360 as I hear its got very low input lag. Jimlad can you tell me how the monitor is once you have used it for a bit? I would love to know if its good or if there is better for the price.
