Spec me £1.8k
Gonna go with reapers build with the 120hz LG monitor, an OCZ SSD and the HX 850w.
One last question, I'm not too keen on that Raven case, won't all the cables be sticking out the top? Will look a bit daft won't it?
Yer there is a top cover, I have two and they are excellent for aircooling. The cables all exit the back in one place so it is easy for keeping things tidy. If you don't like the look of the case there are many more options.
I'd say get the Agility 3 over the Vertex 3, there is no noticable performance difference outside of benchmarks, I own both so save some cash.
The monitor looks like it is the IIyama E2473HDS, personally I'd spend a bit more and get something else but thats just me and my love for all things IPS.
I'm not set on it, just had good experiences, it seems to overclock better than XMS3 likely due to the lower voltages and looks great. Also if you shop around its actually only a few quid more than XMS3.
Was unaware the Lepa B-Series 850W is actually a Enermax NAXN 850W, so that does seem the better deal actually. :)
Pssst, keep it quiet, but overclocking RAM has zero effect for gaming.
Also, unless you have an open bench setup, you can only really see the RAM when you're building the PC in the first place. The XMS3 is going to be exactly the same. Spend the difference on a bag of chips or something.
VTX3D ATI Radeon HD 6870 X2 Edition 2048MB GDDR5 PCI-Express Graphics Card £344.99
(£287.49) £689.98
(£574.98)
Asus VE247H 24" Widescreen LED Multimedia Monitor - Black £164.99
(£137.49) £164.99
(£137.49)
Corsair Professional Series AX850 High Performance 850W Modular '80 Plus Gold' Power Supply (CMPSU-850AXUK) £161.98
(£134.98) £161.98
(£134.98)
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £159.98
(£133.32) £159.98
(£133.32)
Asrock Z68 Extreme4 Intel Z68 (Socket 1155) DDR3 Motherboard £144.98
(£120.82) £144.98
(£120.82)
NZXT Phantom Enthusiast Full Tower Case - Black £109.99
(£91.66) £109.99
(£91.66)
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G) £95.99
(£79.99) £95.99
(£79.99)
Microsoft Windows 7 Home Premium Upgrade DVD - 32/64bit Retail (GFC-00026) £89.99
(£74.99) £89.99
(£74.99)
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX8GX3M2A1600C9) £59.99
(£49.99) £59.99
(£49.99)
Thermalright Silver Arrow CPU Cooler (Socket LGA1366/LGA1155/LGA1156/LGA775/AM2/AM3) £50.99
(£42.49) £50.99
(£42.49)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £40.99
(£34.16) £40.99
(£34.16)
Sony Optiarc AD-7260S 24x DVD±RW SATA Lightscribe ReWriter (Black) - OEM £16.98
(£14.15) £16.98
(£14.15)
Sub Total : £1,489.02
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £22.20
VAT is being charged at 20.00% VAT : £302.24
Total : £1,813.46
these cards are insane here is a review http://www.guru3d.com/article/club3d-radeon-hd-6870-x2-review/20 2 may be overkill but it gets you to your budget :P
According to the Bit-tech review on SB memory it does make a small difference in gaming as you would expect.
Most of the cases being suggested have windows, so you are going to be able to see the memory.
Also Intel suggest 1.5v memory on SB and yes I know most 1.65v memory can be run at rated speed and timings at 1.5v but for the sake of a few quid why take that chance. Just get 1.5v memory and save the fuss.
