You suck at driving.
...Nope he doesn't, it's just common sense, other drivers are not telepathic.
You have driven on a motorway haven't you?
)...Nope he doesn't, it's just common sense, other drivers are not telepathic.
I don't get this, "Sit with indicator on waiting for gap" thing either.
I use my mirrors to look for a gap and when one opens up I indicate to show I'm going to be moving into said gap.
Isn't this how it's meant to be done?
If someone is sitting there with their indicator on you really don't know when they are about to make that move, You see one guy go past and they haven't moved does that mean I can pass safely or am I forced to slow and let them in? Simply because I fear they will move into my path anyway. It's just not the right thing to do.
I stay in lane 3 and move into 2 when I see a porche coming - I think it's much safer because it removes you from most of the lane-changing shenanigans and because people consider it to be the fast lane you get there quicker and spend less time on the motorway.
The idea/hope is that someone will let you out of an otherwise difficult to leave lane. If I see someone in a decent car that is indicating with lights or attitude that they want to join my lane, assuming I am not going considerably faster, I will flash them out.I don't get this, "Sit with indicator on waiting for gap" thing either.
Then you should have fore seen the issue and moved out earlier, or you are simply in traffic and not on a fast moving motorway.
lol
I admire your honesty
I've never had to wait long for a gap when traffic is flowing at a decent pace.
Ah, I see that I am approaching a slow moving vehicle, check gaps but there are none. Now what?
You should have used your crystal ball (without taking your hands of the wheel and your eyes off the road, obviously).
You wait for one, What is so hard about that?
Is it too complex for you?Can't even be bothered with you two. I will do it the correct way and let you continue to do it the incorrect way![]()
