- 24 Jun 2007
- Landan.
Well for a start it works out of the box, anything that has to have third party firmware installed is a no go, either it works from the manufacturer or it's not happening. If you want to spend time installing third party stuff that's your prerogative, I don't have the time or inclination to do it for my own stuff and there's no way I'm going to talk others through it.
The process is: download the firmware, upload the firmware through the existing web interface, reboot. Why put that obstacle in the way when it's literally 2 mins to do?
And do you never update IOS?
They're massively reliable, look up the MTBF for even low end Cisco and Juniper compared to the consumer stuff (where most of the time they won't even quote it).
That I can't argue with, but again, if you buy smart, you can still have an extremely capable and equally as reliable router for ~£50.
Features for another. That is reliable, standards compliant features that work properly and sanely as a network engineer might expect them to. I'm looking at every consumer router and IPv6 for a starting point.
DDWRT on a competent router would offer all, if not vastly more, features than any consumer out-of-the-box job, and indeed would rival some low end enterprise kit:
http://www.dd-wrt.com/wiki/index.php/What_is_"DD-WRT"?#Features
Added to that, performance, a great many consumer routers won't process 40Mbps at line speed even a moderately challenging traffic profile. The third party firmware is usually worse here because it enforces routing in software which isn't particularly well written for efficiency.
Again, I'll concede somewhat on this, it's definitely worth considering. But again, the risk can be alleviated by buying smart and doing your research - the WRT54G handles both 22Mbps ADSL and 50Mbps Cable without issue or complaint.
The airport extreme in my view is a good device, I wouldn't use it as a router but it's a superior wireless access point to any other device in it's price range I'm aware of, it's well built and has some enterprise level features (syslog, SNMP etc) that are usually missing.
This I definitely won't agree with. I know I'm beginning to sound like a DDWRT fanboi (to compete with your Cisco fanboism
) - but offering syslog and SNMP is hardly anything to write home about. Those sort of features are bog standard even on consumer routers ime!More than anything though, it's wireless is bullet proof in my experience.
Whilst I can't argue with the fact that it's wireless is reliable, I take issue with the fact that you're paying a big premium for the brand name - devices that perform the same or better can be had for less, the Apple isn't using high end premium kit inside.
It's missing web interface is a concern but the GUI is exceptionally good on the other hand (better than any web UI I recall actually).
It's more than a concern - it's shocking!! Of course the thick client may be better than a web GUI, but it's hardly a fair comparison - and ultimately it means that the GUI has to be installed just to configure the thing.
Anyway, good geek off
no issues with disconnection's.
- If I need support I'll plug the old router back in
