Mobile Broadband (On a Mac)
15 Oct 2010
Hello,
Basically I'm going away for a couple of weeks and would like the opportunity to go online if we're stuck in one day because its raining or on a night time.
I've been looking at what companies provided the best coverage and Three seem to be the best on that.
I've seen a 1GB Three Dongle for just £15 which is all I need and will be enough Data.
The only question is, will it work with my MacBook Pro? And I've heard that you have to install software for the device to work? If so how do you go about removing that after you've finished (Only had my Mac just over a week).
Thanks :) :D
If they do the software for Mac (I assume they will), then the way to "remove" software from a Mac is to delete it from the Applications folder.
The dongle is £34.99 with 1gb allowance for 30 days.
They supply the Huawei E367 which should work fine on OSX.
I've found a Three Dongle for £15.99 (Just put it as £15 in original post)
Thanks :D Good to know that it'll work :)
