Hello,
Just wanted to ask if my CPU temps are fine. As you can see from my SIG, I'm using HAFx case, push/pull exhaust on H50 and i5 2500k. I've done very little overclocking, 4.0 Ghz. My idle temps are about 37/38/39 degrees celsius. When initialy installing the H50, I had to press it aganist the CPU and then turn. Did that somehow screw up the paste, or are these temps normal?
Any support is greatly appreciated.
 all software temp moitors monitor from a different part, therefore the max temp is different. the MAX temp that SOFTWARE will read is 98c.
