Just recieved the worst haircut ...
A year or so ago my hairdresser messed up and cut down to the skin on a small section. I was pretty annoyed but English mustard for a few nights worked really well. The only issue is getting it on your pillow.
You need to find the biggest butchest manliest man you can find (I'd recommend some very large aggressive bouncers as a place to start) and ask them to rub their man danglers all over your head. The testosterone will enter the folicles directly and you will have hair growth immediately. Most large aggressive men will be very accomodating and understanding if you ask them straight up.
That's not even an issue. If you leave the mustard on the pillow for another night or two it'll grow another pillow. :)
You need to find the biggest butchest maliest man you can find (I'd recommend some very large aggressive bouncers as a place to start) and ask them to rub their man danglers all over your head. The testosterone will enter the folicles directly and you will have hair growth immediately. Most large aggressive men will be very accomodating and understanding if you ask them straight up.
Make sure you have removed the mustart from your scalp before attempting the above.
