CoPilot Live Premium
I used to have CoPilot, but have not bothered with it since Google have released 'Navigation'. I only ever use nav for the last 5 mins or so of my journey if necessary (who really needs nav for main roads and motorways??), so the free alternative works grand for me :)
Can't use the free products as I need maps on the device for when I go into areas of no reception or abroad.
Got it as well - my v8 worked very well and am expecting this to do better - HOWEVER,
(1st bug possibly) - When you close the app ( via home button ) the GPS stays ON and you have to enter the apps menu, double click etc etc... as you did before the bug fix came out for v8, to close the app - anyone else with the same problem ? GPS stays on after app closes ?
One more thing about this new copilot, if you update your firmware on Android make sure you deactivate first, because unlike copilot 8 which worked on any firmware you put on, this one thinks your using a new mobile, so without deactivating first, it won't work when you've updated.
Whats the difference between this and the old version anyway? cant see any change..
-edit-
Also it doesn't actually work yet it seems, heh.
Got it working, just removed it and put it on again. Will give it a go in the coming days.
