The silver arrow looks godlike but the 140mm fans might not fit in my case since the 120mm rad only just fits...
the silver arrow is 163mm tall (although some people have measured theirs and found it to be up to 167mm tall). if you have over 170mm between the motherboard PCB and the side of your case then you will be fine
H100
