Hi all, Had a strange BSOD about 2hrs ago whilst just browsing on the web "A clock interrupt was not received on a secondary processor with-in the allocated time interval". Now I have had a look around Google and looked at the code for this Bsod and it seems the V-core is too low but what I dont understand is that this has just started to happen?
Could my cpu be faulty? All temps are fine, Ram is all fine and tested with memtest and psu seems to be fine, I do know that that Asrock z68 boards have had this issue though can not find anything on my Gigabyte board with this issue.
I use Hardware monitor and that gives me two readings for the cpu, one is cpu v-core which is @ 1.06v and the other is 1.24v cpu, I also use the intel speedstep and other power saving features via bios.
Only had this cpu/mobo/ram about two months, So I am eager to get this resolved with-out the hassle of RMA.
Any Ideas guy`s would be greatly appreciated.
, right now I am just trying to get stable @ 4.2ghz, as I am happy at this point for a 24/7 OC but would like to see my Volts as low as can get them, I think ideally around the 1.28v range would be good as right now my temps are avg 70c across the 4 cores.
, hopefully that might point me in the right direction.
