We present two more fantastic hardware deals this morning which will improve your new system. You will not be disappointed with either of these awesome products!
Lepa W-Series 600W '80 Plus' Power Supply @ £54.98 inc VAT
Designed by engineers from CWT & Enermax combined these mid range PSU's are ideal for any gaming systems. Lepa are new to the power supply market, but the company behind Lepa are one of the best known PSU manufacturers in the world. You cannot go far wrong with any of the Lepa series PSU's.
- 80 PLUS® certified with peak 85% efficiency
- High efficiency 5Vsb circuit helps system to meet EU ErP Lot 6 2010 standby low power consumption requirements
- 12cm fan with thermal programmed speed controller providing silent cooling performance
- Active PFC universal switching circuit improves Power Factor value up to 0.99, reducing AC line reactive power loss to minimum level and automatically adopting AC voltage from 100~240V
- 8P PCI-E connector supplied supporting extreme graphic cards
- Protected by Over Power, Over Voltage, Over Current, Short-Circuit, and Brown Out protections circuits
- CPU 12V connector rail with >18A output to support next generation >6 cores processor structure
- Extended CPU connector cable to 60cm facilitates installation with bottom-mounted-PSU chassis
- SATA power connector with 3.3V rail to support new generation SSD
- 3 year warranty
Only £54.98 inc VAT.
ORDER NOW
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £221.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Lithography Process: 32 nm
- Cores: 4
- Threads: 8
- Frequency: 3.40 GHz (Turbo Mode 3.80GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1350MHz Turbo)
- Cache: 8 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 1yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.35-1.38v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Only £221.99 inc VAT.
ORDER NOW
- 3 year warranty
ORDER NOW
- Cores: 4
- Threads: 8
- TDP: 95W
- Socket: LGA1155
- 1yr Warranty
ORDER NOW
