Hi all, putting together the final touches of my rig. Its going to be a big upgrade that will hopefully last a while. Going from a 775 setup so it's going to be one heck of a jump.
Couple of questions to check.
1. The ASrock seems to be a board that is getting good clocks. However with a crossfire setup the layout could be interesting for an aftermarket sound card. Should I be able to get away with a pci-e card in the slot nearest the cpu?
2. Is the power supply good enough for a clocked i7 + crossfire? I would have thought so, just checking.
I may swap out the kingston for xms3 memory. Can you critique this:-
Hazro HZ27WA 10-Bit 27" LED Widescreen Professional Monitor - Black £491.99
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - OEM £221.99
Sapphire ATI Radeon HD 6950 2048MB GDDR5 PCI-Express Graphics Card with FREE DIRT3 Game *2 429.98
OCZ Agility 3 120GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-120G) £169.98
Asrock Z68 Extreme4 Intel Z68 (Socket 1155) DDR3 Motherboard £144.98
Corsair Enthusiast Series TX 750W V2 High Performance '80 Plus Bronze' Power Supply (CMPSU-750TXV2UK) £96.98
Asus Xonar D2X 7.1 PCI-E Sound Card 89.99
Fractal Design Define XL Full Tower Case - Black Pearl 89.99
Hitachi Deskstar 5K3000 2TB SATA 6Gb/s 32MB Cache 5900RPM - OEM *2 £103.96
Thermalright Silver Arrow CPU Cooler (Socket LGA1366/LGA1155/LGA1156/LGA775/AM2/AM3) £50.99
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX) £49.99
LG CH10LS20 10x BluRay-ROM / 16x DVD±RW Drive - Black (Retail) £49.98
Akasa SATA-III 50cm Rounded DAYGLO Blue Data Cable (Right-Angle Connectors) £4.99
Akasa SATA-II 60cm Blue UV Data Cable *2 £7.96
Total 2034.32
Total 2034.32
