Today only, power your system with Nvidia and dominate all your games at max resolution. This card from a PNY is reference design making it compatible with watercooling solutions. (As featured on our watercooled'd pc thread)
Sit back and relax to the sound of Philips 5.1 Speakers. Perfect for gaming, music and films and be into the thrilling cinema style experience.
PNY Geforce GTX 580 1536MB GDDR5 DVI HDMI PCI-E Graphics Card - (GMGTX58N2H15ZPB) @ £341.99 inc VAT
NVIDIA GeForce GTX 580 features with screaming performance and a vapor chamber thermal design. The GTX 580 rips through the games while running quieter than the previous generation. As you've come to expect from a GeForce GTX GPU, GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX, and SLI. GeForce GTX 580 - don't play DX11 without it.
Features:-
- Core Clock: 772MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4008MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1544MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 3 Years
*** REFERENCE PCB DESIGN ***
Only £341.99 inc VAT.
ORDER NOW
Philips SPA2602 5.1 Surround Sound Speaker System @ £29.99 inc VAT
Perfect for MP3, PC, TV and more.
Connect your speakers to all your gear. A great way to listen to your MP3 player, PC, TV, CD, DVD and all your multimedia stuff.
Sound
- Bass enhancement: Analogue Bass Boost, Bass reflex
- Frequency response: 35 - 20 K Hz
- Loudspeaker Enhancement: Magnetic Shielded LSB
- Music Power: 90 W
- Volume Control: Analogue Volume Control
- Wires: Fixed Wires
- Output power (RMS): 45 W
Loudspeakers
- Satellite speaker drivers: 3"
- Subwoofer driver: 4.25"
Connectivity
- Audio input for data: Stereo Audio (3.5 mm jack) 1 x
- Cable length: 1.5 m
- Connector: 3.5 mm stereo
Only £29.99 inc VAT.
ORDER NOW
Features:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
Sound
- Music Power: 90 W
Loudspeakers
Connectivity
ORDER NOW
