I was just mulling over some ideas in my head, solar is all well and good but the panels are expensive and the UK doesn't get masses of sunlight.
I was thinking, what if you had a small wind turbine mounted on the house (descretely) and then you used a bank of lead acid batteries to hold the charge? What would you then require to feed that electricity into your home?
