Best Gaming card for £200 ? Max settings / 1080p
17 Oct 2007
Some where in England
Simple question .
What single or 2 x Card combo is the best at around £200 for 1920 x 1080 Gaming ? Max settings .
Im also looking for a card that i can maybe sli up later for when BF3 comes out aswell..... so looking for a card ill keep for a year or so.
Probably the best 2 cards that fit the bill are the 560 Ti or the 6950. Both are good on their own and scale very well when stuck in SLI or Crossfire. Personally I would say the 560 Ti as I've owned one and it's a great card.
Beg, borrow, and steal for the GTX570 on offer.
Failing that, i'd get the 6950 if I was running a 24" or bigger screen, or the 560Ti if I wasn't.
for your resolution, I would consider 560ti. cheaper and does good job at this resolution.
If I wouldn't be gaming at 2560x1440 I would get 560ti instead 6950 2gb
