MSI 6970 Discontinued?
14 Sep 2010
Scotland
Good Day. I was looking to get a second MSI 6970 (R6970-2PM2D2GD5) for my system. I bought my current 6970 from OCUK and is now out of stock. I have searched the usual places but all seem to be out of stock. Has this card been discontinued? Cheers.
Yeh I thought that. I dont HAVE to have the same card, but it will just annoy me. Not sure why there is no stock available for them.
He maybe has a window on his case, Lets face it we all want two cards which match perfectly, Other option is to custom Cool both cards. I can find lightnings but not the stock MSI's.
Sorry :(, Good luck with your hunt, Did you check members market?.
it seems a lot of MSI cards are on back order across most shops online as i was going to get another 6950 twin frozer 3 for mine but then price went to £220 and now back at £200 but now stock on order :\
I found this one at the first place i looked...
Where can you find 6970 Lightnings? Been looking for a while, is there some obvious place I haven't checked?
I just used Googled it, Showed afew companys, Pretty sure if you really wantone OCUK can get you one, You can only ask!. :D
I would get this instead:
http://www.overclockers.co.uk/showproduct.php?prodid=GX-128-MS&groupid=701&catid=56&subcat=1752
Try the product suggestion forum...
http://forums.overclockers.co.uk/forumdisplay.php?f=67
Can anyone tell me if OCUK will be getting the MSI R6970-2PM2D2GD5 card back in stock soon? Seen a few on another website but I dont trust 'em!
