Just out of interest does anyone have trouble playing this smoothly? Spec in sig but my 460 is currently clocked at 800mhz core and 3908mhz memory.
Game usually hovers and around 35fps and sometimes bombs down to around 15fps when it kicks off. Weird thing is though if i have everything set to high at 1380x768 res and 2xaa and 8xaf it runs pretty much the same as everything in low settings in both Directx 10 and 11. Now installing newest drivers for the 460.
any ideas?
It may not be your computer.
BC2 for me, ran perfectly fine and smooth since owning it, then around the middle of May there was a PunkBuster update which caused the issue of the PnkBstrB.exe service using a lot of the CPU (40-50%) making the game feel choppy/loss of frame rate.
You could check your task manager when in a BC2 server to see if the above service is using your CPU a lot.
Myself and a few friends (who are also on dual core processors) have this issue as do a lot of people on the EA forums, but it does seem to only affect dual core users.
