- 5 Jul 2011
Don't need anything other that the actual parts and case.
This is almost purely for gaming (and web browsing and the basic stuff ect.)
I'll be gaming on an 1080p screen, but Im fine playing 1600x1280 (or whatever it is
) as its not the biggest screen.
Cpu Im thinking
- I5 2500k (but not sure if it's possible to fit it in with a tight budget like this)
- Or go the AMD route with this http://www.overclockers.co.uk/showproduct.php?prodid=CP-304-AM&groupid=701&catid=6&subcat=1943 or another quad core
GPU - I was thinking maybe a 460 or a 560 (dont think a 560ti would fit in the budget) or a 5850, not sure.
Memory - 4gb corsair 2x2 will be fine, right? http://www.overclockers.co.uk/showproduct.php?prodid=MY-303-CS
Case - No idea, I probably won't be overclocking for a good while as this is my first time building a pc.
HDD - 500gb, any brand should do right?
power supply - would like a reliable one, not sure what Wattage I'll need at all though.
Motherboard - No idea, I'd like quite a few USB ports but probably won't be upgrading for a long while.
I'd also like to know how hot/loud the build anyone gives will get, hopefully I wont need to worry about temperatures if i'm not overclocking but would like something quiet so maybe getting an aftermarket fan instead of a stock CPU fan would be a good idea.
Help will be greatly appreciated, thank you
And hello everybody, first post!
EDIT: as Ill be gaming on a TV screen with either HDMI or VGA cable, will this be a problem as I need to install drivers for it to work with HDMI/VGA first?
) as its not the biggest screen.Cpu Im thinking
