Non-Steam games broken icons
30 May 2009
Maidenhead
Got a little issue with my Steam. All the non-Steam games I have added have broken icons like this:
Now, it should be showing as the small icon that the Warcraft III exe has, but isn't coming up at all for some reason. Even when I try and select it, nothing changes.
Any ideas? It used to work properly for me, but has broken ever since I re-installed Steam.
Yeah this works. I don't like it though. I wish there was a way to add proper grid images to non-Steam games so they don't look out of place.
Yeah, I tried to re-add them and it's still broken for me :( Really annoying now. I might try to reinstall my Steam, and then re-add my mklink for the Steam apps folder. It's just a bit inconvenient really!
orderoftheflame, I tried to add a proper .ico file and it doesn't show anything. Doesn't event extract anything from the .exes :( I will try a reinstall.
Reinstalled Steam, and still no joy. When I go to actually add a game, all the icons in that listing are totally broken. Not good :(
Anyone got any suggestions as to how to fix this? It's doing my head in. Shouldn't be like that. But given Steam doesn't even display the icons of programs in the "add non-Steam game" browser, seems like it's not going to be easy to fix :(
Ive had this before with fifa 11, are you adding any launch extensions or going back into the properties of the shortcut once youve added it? Or are you renaming what you would like the shortcut to be called? I notice you have a "The" in the name where the working one doesnt
Try adding it without changing anything, but if you goto the properties then out again i think it breaks it
Im not at my pc now but will have look later and report back with the solution
No launch properties added. And it breaks before I edit anything. The minute I add the shortcut, it is broken.
Like I said, if I go to "Add a game", then the browser comes up, none of the games/programs have working icons. They are all just white icons. It used to work for me a while ago, on my old install of Windows, before I moved to my SSD. I didn't really use the feature much. Now that I want to use it, nothing appears. It's so stupid, as I have no idea why it's doing it!
Probably better off posting this on the steam forums or making a ticket about it. Pretty clearly a bug with steam, and bugs can't get fixed if the devs don't know about it :p
I wish you could. Not yet unfortunately. :(
Damn it, I knew that was the case.
Here's hoping they will implement it some day, the Grid view is awesome and makes me want to play all the games I have but I end up switching to the normal view once the tenth of the library is made of non-steam games.
I guess I will just live with it for now. It can't be a Steam issue, as other people have the small icons working, so it must be an issue with my PC and my Steam :(
Will give it a go. I am getting this when I go to add a non Steam game:
As you can see, none of the icons are appearing there. So definitely a problem :(
Found one other person on the Steam forums who has had this issue for a while. Apparently is has persisted across various OS installs and Steam re-installs.
Anyone got any other ideas as to what could fix it?
