obse.silverlock.org
~ Description ~
This MOD can be used in Nehrim.
Estrus is a unique mod that adds certain, sexual spells to Oblivion. It allows you to cast them both on yourself and any female NPC. There are six unique spells and two items for adjusting them to your personal desires.
-Estrus Spell
The normal "Estrus Spell" comes in three variations: cast on target, self, and explosion.
They do exactly what you'd expect. Whatever target you choose, as long as it's either yourself or female, will give in to it's sexual desires.
One speciality about the normal "Estrus Spell" is that it's effect changes whether you are in sneak mode or not. Check the screens. Explosion will target all female NPCs in the area... watch and enjoy.
-Estrus Roper
With this so very powerful spell you summon a mighty roper, a sexual monster. It will restrain and please your target, whether she wants it or not. Again, you can choose from cast on target, self and explosion.
-Estrus Configuration
This scroll is added to your inventory when you start the game. You can adjust the mod by using this. See the section below.
-Estrus Position Adjuster
important:This tool needs keyboard with ten-key.
By makeing player equip with PositionAdjusterRing and putting crosshair on target NPC, You can adjust NPC and Roper Position.
- 0 : reset position.
- 5 : print current position-info to console.
- 4&6: rotate roper (left / right)
- 2&8: move roper (downward / upward)
- 7&9: expand / shrink roper
- 1&9: adjust distance
~ Options ~
Estrus grants you quite some options to adjust the mod to your taste. For quick information while playing, check your Configuration Tool.
-Nude configuration
Adjust the way the victims of Estrus are stripped. You might want Estrus to only strip the lower body? Or leave the headgear? You can.
-Pattern configuration
You like one animation in particular? Find out which pattern it is and make Estrus always use it. Works both for the normal "Estrus Spell" and the "Summon Roper" spells.
-Equipement configuration
If you have a special outfit you'd like Estrus to force all victims to wear, use this option. It's simple: wear the desired outfit, click "Register Equipement" and enable the Equipement changer. Done.
-FX and light
You can also enable/disable the light and effects of Estrus. You don't like the squirting? Disable it. You don't like the light, because it ruins the atmosphere of your screenshot? Disable it.
-Bust Size Config
By using this menu you can adjust the animations of Estrus to your used body mod. In case of any clipping errors you might be able to solve them with this. It's just meant for fine-tuning your mod.
-Onlookers
With this feature you can choose whether people come to stare at the victims of Estrus or not. If you don't want the whole town to watch you please yourself...there you go. On the other hand, if you like the whole town to watch... well, it kind of explains itself.
-Flee
Usually vicitims of Estrus are embarassed after the effect ended, they duck and cover. You might change this as well...
