Might not show if your using the discrete cards.
that sux, im guessing this is a known issue that ASRock are working to resolve?
Could possibly be an issue with the IGP on the CPU? pity you can't try another 2500k to find out.chippy08 said:Yes they know but i have given in now and have returned the board.
What you going to do, get another Asrock, or try a different motherboard, they might not find it even faulty which would be a pain in the ****.
The problem is affecting more people as well. Not sure which make to go for did like the asrock apart from that problem.
could you not just get a cheap descrete GFX until the problem is resolved?
Hi how long did you have the board for? i have had my board for 6 wks but not sure if they will take it back.. BSOD'S all the time but if i use a Asus board its fine.. Ta
