Do you apply anti-perspirant to hairy pits?
If you wash yourself everyday it doesn't matter if the hairs under your armpits are long or short.
Also Sure is probably best antiperspirant I have come across.
But if you don't wash yourself regularly it doesn't make a blind bit of difference, its obvious but perhaps not so obvious to readers of this thread.
wiki says the hair is there to reduce the moisture on the skin and actually reduces the numbers of bacteria that create the odor.
Yes, because I don't shave my pits.
If you swim, play basketball or similar then I can understand why you'd shave your pits.
I have no need though :)
Play basketball? How the hell did that end up on the list lol. I have played basketball at international level and haven't known anyone to shave their arm pits :s
Edit: google agrees that a lot do! How random
All men should trim their armpit hair and keep it neat... and by that I mean so that it doesnt stick out everwhere when you wear a sleeveless top, not shaved bare... you're not a woman. Same with your pubes, keep them tidy and under control, it's basic grooming and the ladies appreciate it.
