- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
After the OCZ 850w GOLD PSU deal Antec have come in to smash up this deal. Also we are offering a free copy of 3D Mark 2011 Advanced.
Stock will be arriving later this week, but pre-order now.
Antec TruePower New Modular 550W '80 Plus Bronze' Power Supply @ £64.99 inc VAT
New features. Same true power. The TruePower New series by Antec offers users an advanced power supply solution, striking the perfect balance of reliability, efficiency and quality. With DC to DC voltage regulator modules, a 120mm PWM fan, and 80 PLUS® Bronze certification, TP-550 is the ideal solution for elite system builders and quality-minded enthusiasts alike.
- NVIDIA™ SLI™ - ready certified
- 80PLUS® Bronze Certified saves energy and lowers your electric bill
- DC to DC voltage regulator modules for greater system stability
- 120mm PWM fan runs up to 50% quieter than standard fans
- Advanced Hybrid Cable Management improves airflow and reduces clutter
- Double layer PCB optimizes cooling efficiency and allows for heavy duty components
- Universal Input and Active Power Factor Correction
- Supports dual GPUs and dual/quad core CPUs
- 4 +12V output circuits provide stable power
- ATX12V v2.3 and EPS12V v2.91
- 1 x 6 pin and 1 x 8 (6+2) pin PCI-E graphics card connectors for TP-550
- 2 x 6 pin and 2 x 8 (6+2) pin PCI-E graphics card connectors for TP-650, TP-750 and - Industrial grade protection
- Safety approval: UL, CUL, CE, CB, FCC Class B, TUV, CCC, C-tick, BSMI
- Dimensions: 86mm (H) x 150mm (W) x 150mm (D)
Only £64.99 inc VAT.
ORDER NOW
Antec TruePower New Modular 650W '80 Plus Bronze' Power Supply @ £74.99 inc VAT
New features. Same true power. The TruePower New series by Antec offers users an advanced power supply solution, striking the perfect balance of reliability, efficiency and quality. With DC to DC voltage regulator modules, a 120mm PWM fan, and 80 PLUS® Bronze certification, TP-650 is the ideal solution for elite system builders and quality-minded enthusiasts alike.
Only £74.99 inc VAT.
ORDER NOW
Antec TruePower New Modular 750W '80 Plus Bronze' Power Supply @ £84.98 inc VAT
New features. Same true power. The TruePower New series by Antec offers users an advanced PSU solution, striking the perfect balance of reliability, efficiency and quality. Still delivering the “true” power that users have come to expect from Antec’s TruePower family, the TP-750 introduces sophisticated new features like DC to DC voltage regulator modules to ensure greater system stability, and a 120mm Pulse Width Modulation fan (PWM) which runs up to 50% quieter than standard fans.
With 750 watts of power, the TP-750 is also 80 PLUS® Bronze certified, delivering you quality power that is not only reliable and quiet, but incredibly energy-efficient. With hybrid cable management to enhance airflow and reduce clutter, Antec’s TP-750 is a truly advanced PSU solution for both elite system builders and quality-minded enthusiasts alike.
Only £84.98 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
