As posted elsewhere, but I'm looking for a quick response.
This is a question about Racer X shred classic Scarified.
Thanks.
As you know, the bach section features a load of pull offs and picking all over the d to high e strings. For the first bar, the first two notes at a picked 18th fret on the g string to 14th fret - a move that is obviously done with the little pinky finger and first finger. The shape is repeated for the second bar. However, the 'shape' changes on the third bar to one that is used for the majority of the section. The third bar starts with a pull of on the g-string 16th-13th frets. However, is the 13th fret held with your first or second finger? It's a lot easier to use your first finger on the 13th fret initially, but then you would have to move your hand to get the 12 fret on the B string.
I've always used my first finger, but I think at speed, it would be cleaner if I used my middle finger. Thoughts? What do you use?
To help make sense of this, here is the offending bit:
As you need to use your first finger on the 12th fret B-string, should you use your middle finger for the 13th fret g-string?
Also, I always pick the last section of notes and never bother with that last pull off as noted by the curved line in that tab. What do you do?
Thanks.
