Sudden drop from 18650 to 13760?
3 Mar 2003
Canterbury
Hey guys! I have been using my connection at a stable 1.85MB/s for years now and today its decided that my maximum speed is about 1.37?
I have checked and the SNR target: 3 dB as normal - but will only connect at about 1.37? Maybe my router is going flaky on me?
Has the sync rate dropped or is this just the throughput?
If the sync has dropped and the SNR is the same then that would indicate the line quality has degraded slightly. As if the line remains the same, lowering sync speed should theoretically up the SNR margin slightly.
Sync speed dropped. My thinking is my router is glitching or maybe a fault somewhere. Not too bothered at the moment but if it persists I think I will give the chaps a call.
Just an update. Noticed today my SNR was 8 so reconnected and im back at just over 1.8megs. :D
