Upgrade or Sli for gtx460
18 Mar 2010
Hello all
I recently installed my new i7 Sandybridge 2600k and I've got it running alongside my EVGA 460SC.
I'm just wondering what people would recommend as an upgrade for the 460?
I don't really need an upgrade, just a want really.
Is it possible to run SLi with two different brands of GTX460?
Or is it better to upgrade to a GTX5xx series card?
I've been looking at the GTX560, but graphics cards tend to confuse me a fair bit.
Any advice would be appreciated.
Ta.
Tony
I like to try my luck at 1920 x 1200, then drop it down until I can find a good compromise of gfx settings and res.
So far the i7 and the 460 are working well; but I'm looking for a game to give it a good thrashing. Might have to dust off Crysis.
I think a good test for it might be seeing how far I can push the settings on Metro 2033, as that used to run quite poorly on high specs with my old q6600.
So, if I've got a EVGA gtx460, can I put in another 460 from a different manufacturer. Or is that a no go?
Thanks for all the info thus far.
When you have insufficient vram you get considerably more lag spikes/stuttering.
http://forums.overclockers.co.uk/showpost.php?p=19557689&postcount=45
For this reason I do not recommend putting 1GB cards into crossfire/SLI. A single GPU setup with 1GB vram is fine in most cases, but multi-GPU setup with 1GB vram per GPU can't be recommended.
