Anyone having trouble because of the heat this summer? Had to take my overclocking off everything. I have 2 5830s in crossfire, and a Titan Fenrir pointed right at them (Can't point anywhere else), so all the warm air from my graphics cards and northbridge heatsink gets sucked straight into the cooler.
CPU is a 965BE C2, 140W. It runs hot. Very.
I'm thinking upgrading to a D14 or Silver Arrow would sort it? I will probably upgrade the fans on whatever I get, because I want them all to be connected in together so that the speed is synchronized. I'm guessing I can get the PWM line from one fan, then wire the other 3 lines together and plug them all into the CPU header, but I'm worried this might not provide enough power?
D14 seems to get slightly better reviews to me, so plan at the moment is one of those, but with 3 matching fans. Unless this isn't advisable?
EDIT:
Actually, will probably just get one of these: http://www.overclockers.co.uk/showproduct.php?prodid=CB-031-AK
This will mean I can have a big cooler with 3 fans, all variable speeds controlled by the CPU temp. Sorted. But which to choose, Silver Arrow or D14? D14 seems to get better reviews, but the D14 setup would cost me £108.27 whereas the Silver Arrow would cost £67.33. Might be worth looking at watercooling instead?
EDIT:
