Computer is loud.
17 Aug 2010
London
Ok so I built my new rig 1 days ago and the fans are quite loud.
Any solution. I tried to use speed fan and I set it so it does the setting automatically. At first it was quiet then after some gaming it got loud.
Anything that will keep the temperatures low. If they are too high, then increase the percentage until they are at a level that you can work with.
I have a 2500k. What temperature is normal for that in prime?
I think 75% is good enough. Around 55 degrees on prime
Anuraj told me to post here so he didn't have to double post, I told him to edit his post but he said no one would read it.
