I have an apology to make, to googalymoogaly. Seems we are both right and wrong. You sent the old grey cells working and i had to find out about flow rates and the best way to cool a system and in my search i came across this old forum link which i found very intresting reading and also helped enlighten me to the pros and cons of liquid cooled loops ( Hope it is ok to post this link and i do not break any forum rules but others my find it helpful as well ) http://www.overclockers.com/forums/archive/index.php/t-210844.html
I've tried 38mm fans in the past and ended up getting better 25mm fans, if you can move them away a bit with a 5-10mm shroud that can help a lot, but having two push/pull fans at slower speeds on the thicker rad will give you a better, quieter effect than 1 38mm fan.
