2014 F1 Technical Regulations PDF
2014 F1 Sporting Regulations PDF
F1 cars to use electric power in pits from 2014
F1 cars will have to run on electrical power only in the pit lane from 2014.
The technical rules for 2014 published by the FIA state cars must run “in electric mode” with “no ignition and no fuel supply to the engine at all times when being driven in the pit lane.”
- Engines will be able to be started from inside the ****pit with no additional equipment needed.
- KERS capacity doubled - 120kW
- Narrower front wing and simpler endplates and flaps. 1,650mm down from 1,800mm today.
- Weight increase - 660kg up from 640kg today.
- Minimum weight for KERS and Engine is now 155kg. Up from 95kg for the engine alone.
- KERS only in the pit lane.
- 8 speed gearboxes only.
- 1.6-litre V6 engines, limited to 15,000rpm, down from 18,000 today.
- V6 will be a fixed 90° angle with the turbo inside the V and the exhausts outside.
- The FIA will allow a dispensation in 2014 when teams nominate which gear ratios they will use: “For 2014 only, a competitor may re-nominate these ratios once within the Championship season, in which case the original nomination becomes immediately void.
