- 27 Oct 2006
- London
Yea I think it's coming down to that will do the cables tomorrow.
Just remember that it won't silence your machine but will help iron out any resonance. I didn't like the heap of cables around the GPU.
Overall you'll get better airflow so your components won't need to work as hard, resulting in lower fan speeds.
I remember the 1st decent GPU I bought and being astonished at how noisy it was - Then came the modding - Reseating or replacing the cooler etc etc
Even now - I have the MSI Cyclone 1G/OC which is 'supposed' to have a decent quiet cooler but I still find it noisy at load.
If you really want to silence it then get this ...
http://www.overclockers.co.uk/showproduct.php?prodid=HS-080-TR&groupid=701&catid=57&subcat=787
Not sure the 570 is supported but google tells me that someone has fitted it
		 Any drop in temperatures? Even a degree or two?
