Hi,
My Tpower mother board decided to die on my this week.
I'm looking to replace it with something not too expensive.
Am I right in thinking I have to get a x58 spec'd board?
I found
Gigabyte GA-H55M-UD2H Intel H55 (Socket 1156) DDR3 microATX Motherboard @ £66.98 inc VAT
which lists support for i7 and it's FAR cheaper than anything i can find for my i7 - did they change the socket type, or is it backwards compatible?
I would like a mobo which has:
6 RAM slots is a must.
4+ SATA ports
1 at least SATA 6GB (as will get an ssd soon)
usb 3.0
http://www.overclockers.co.uk/showproduct.php?prodid=MB-429-AS
has good reviews.
any thoughts or advice? wont be going crazy with an OC maybe 3.4 to 3.6 from my i7-920 as I got before.
Might pay a little more if it had a high quality sound card, might decide to get an after market expansion bay card.
Thanks!
A
I found
4+ SATA ports
usb 3.0
has good reviews.
Thanks!
A
