Who's bought one of these? Did it reach 4.8 on your setup?
Reason for asking is that I went for one as a last resort, after going through 3 2500's already looking for one which will do 4.8+ on 1.4v or under. Let me say right now that as this chip is intended for a dedicated flight simulator X rig, I'm one of the very few who actually do need the high speed, so isn't just a case of wanting 4.8+ for e'peen rights
Anyway, I ordered one of these "guaranteed" chips after some deliberation, and figured that as my core components are otherwise almost identical to the OCUK testing setup, there was a very good chance that it would also hit 4.8 on my machine. This was not to be.
I'm not looking for OC'ing help as I guarantee you that I've tried every combination of every variable in BIOS, as well as well as with different RAM/GPU, but rather just want to know if anyone else is in the same boat with regard to these chips? I'm toying with the idea that my mobo might be the problem, but after borrowing an i7 last night which did hold a 48 mult without any problems on my board I'm not so sure. The highest mult it will remain stable on is 45. 46/47/48+ all fail prime/linx within two minutes with stop code 101 (vcore). This is on 1.4 which is both my personal limit at the moment, as well as the stated OCUK limit for testing.
The other thing I wanted to ask anyone who's bought one is did you receive an OEM or a retail CPU? The product page says it's an OEM chip, yet I received a retail one (although opened). For this reason I'm concerned that I may have been sent the wrong processor in some kind of mixup, perhaps having someone's RMA sent to me by mistake. On the other hand it could be a brilliant chip that they kindly picked out for me due to my dispatch being a day late, and it is just my mobo that doesn't get on with it. Of course I've sent them a message about this all, but have yet to receive a reply.
Right, that was all probably rather long winded for what really is a simple couple of question for anyone who has bought one of these. Sorry
Finally, I hate each and every one of you who has bought a sandy and found it to do 4.8+ out of the box under 1.4v first time. Even more I hate those of you who will never actually use that speed, but not as much as the ones who sit with a god-like chip at stock speeds! Lock up yo houses, lock up yo cases cause I'm coming for you motherclockers!
Anyway, I ordered one of these "guaranteed" chips after some deliberation, and figured that as my core components are otherwise almost identical to the OCUK testing setup, there was a very good chance that it would also hit 4.8 on my machine. This was not to be.I'm not looking for OC'ing help as I guarantee you that I've tried every combination of every variable in BIOS, as well as well as with different RAM/GPU, but rather just want to know if anyone else is in the same boat with regard to these chips? I'm toying with the idea that my mobo might be the problem, but after borrowing an i7 last night which did hold a 48 mult without any problems on my board I'm not so sure. The highest mult it will remain stable on is 45. 46/47/48+ all fail prime/linx within two minutes with stop code 101 (vcore). This is on 1.4 which is both my personal limit at the moment, as well as the stated OCUK limit for testing.
.Finally, I hate each and every one of you who has bought a sandy and found it to do 4.8+ out of the box under 1.4v first time. Even more I hate those of you who will never actually use that speed, but not as much as the ones who sit with a god-like chip at stock speeds! Lock up yo houses, lock up yo cases cause I'm coming for you motherclockers!
