need to equip grenades and knife?
AWSOME
Don't need to equip nades or knife, you have the option to, or you can hit F for the knife or G to lob a grenade.
AWSOME
sided weapons? need to equip grenades and knife?
AWSOME
Don't need to equip nades or knife, you have the option to![]()
+1
But the equipped knife is better! Are equipped nades better?
Don't need to equip nades or knife, you have the option to, or you can hit F for the knife or G to lob a grenade.![]()
i thinkthe firstg time i too kof i nbf2 it went u pand all was good then it leaned to the ight i move the mosue elft it keept going over to the right i moved the mosue right it kept oving over tothe right i pressed everything i could then the chopper landd upside down on to the people on the pad >.<
seem to get killed from miles away or from unseen person
can i say i dont like it ? will play some more but so far its not grabbing me .. seem to get killed from miles away or from unseen person . feels disjointed ...hmm dunno i need more time playing but not a great first impression
I dunno if the equipped knife is any better, ive only managed to knife one person and that was using the f key which has the longer animation. Grenades using the key function the same as BC2.
It needs a killcam imo, theres a ton of "unseen kills" to say the least, id imagine mainly by gits hiding in the foliage which makes them impossible to spot.
Hey it worked for Ace Modder
Bit BF2'ish you mean.
No it's becuase when you're are spotted the enemy see that spot right across the map and then you experience a hail of bullets coming out of nowhere, the orange triangle above your head is a right give away.
Shut up about the spotting.
It's an alpha. They have plenty of time to sort it out, plus you've already whined about it many many times before. We get it.
You know hit Q a few times whilst looking at the bush and you will get the triangle of noobness and a kill.
Jump in the APC and do some bush trimming.
